[gdal-dev] Control overview block size
Even Rouault
even.rouault at mines-paris.org
Tue Jun 10 05:48:20 PDT 2014
Selon "Etienne B. Racine" <etiennebr at gmail.com>:
> Hi List,
> Is there a way to control the block size of overviews and inspect that
> block size from gdalinfo ?
> I have a raster with 256x256 block size.
> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
> I'm trying to feed the images to a program that seemingly supports Tiffs
> with internal overview of the same block size than the image.
> I've tried >gdaladdo --config BLOCKXSIZE 256 --config BLOCKYSIZE 256
> image.tif 2 4 8 16 32
> gdalinfo:
> Overviews: 8655x5655, 4328x2828, 2164x1414, 1082x707, 541x354
> But I couldn't find a way to inspect the overview block size to confirm
> they are 256x256 since I get the same results if I set BLOCKSIZE to 128. I
> suspect these options are ignored in gdaladdo.
The right name is GDAL_TIFF_OVR_BLOCKSIZE. See http://gdal.org/frmt_gtiff.html
> Any way I can 1) control the overview block size and 2) inspect the block
> size ?
Not directly with gdalinfo.
With Python :
from osgeo import gdal
ds = gdal.Open('your.tif')
print(ds.GetRasterBand(1).GetOverview(0).GetBlockSize())
> Thanks for your help,
> Etienne
