[gdal-dev] Asking about feature field types of Shape File (SHP) ?
Ari Jolma ari.jolma at gmail.com
Mon Jun 16 08:05:13 PDT 2014
On 06/04/2014 11:45 PM, taibc wrote:
> Hi everyone,
> I created the shape file by usinge the feature filed type: OFTInteger.
> But when I open the file in Arcgis (ArcCatalog) the data type is: Double
> (not integer).
> Do you know how to fix this (I want it is Int) ?
Dear Tai,
This is a bit old email so I'll answer from my head. I believe you need
to set the length of the Integer field to be short enough. If I remember
correctly there is a ticket on the issue, but it is deemed as a feature,
not a bug.
Ari Jolma
> Thanks and regards,
> Tai
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Asking-about-feature-field-types-of-Shape-File-SHP-tp5144127.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
