[gdal-dev] OT: openev(2) alternative?
Joaquim Luis jluis at ualg.pt
Fri Jun 20 07:42:18 PDT 2014
On 20-06-2014 15:16, Vincent Schut wrote:
> On 06/20/2014 04:03 PM, Joaquim Luis wrote:
>> On 20-06-2014 14:45, Vincent Schut wrote:
>>> On 06/20/2014 03:39 PM, Joaquim Luis wrote:
>>>> If you are on Windows and 32 bits is not a (severe) limitation, I
>>>> think Mirone (http://w3.ualg.pt/~jluis/mirone) satisfies those
>>>> requisites
>>> Ah, sorry, should have mentioned that: I'm on linux (64bit). 32 bit
>>> is a limitation anyway, I regularly need to view very large
>>> images... Btw building experimental stuff is no problem.
>> Ah.
>> It can be made to work on Linux as well but than one needs Matlab (no
>> 32 bits restriction in that case)
> Hmm, sorry, that's not going to work either... No Matlab here. Would
> it work with Octave?
> I'd prefer a truly open source solution anyway, if possible. However,
> closed-source but free options are also considered.
Nope. Octave is too primitive and end of the line.
I prefer open source too ... when I'm able to make it work with it. Will
hopefully work one day with Julia (already started playing with the very
first steps)
