[gdal-dev] ArcGIS RestAPI JSON Polygons
Even Rouault
even.rouault at mines-paris.org
Thu Jun 26 14:32:51 PDT 2014
Le jeudi 26 juin 2014 23:21:58, Jeremy Palmer a écrit :
> > Looking at the ogresrijsonreader.cpp code I can see I assumed that a
> > esriPolygon was just a OGC Polygon, so with outer ring first and then
> > inner rings. Fixing the code to support multi polygons should basically
> > be a matter of calling OGRGeometryFactory::organizePolygons.
> Thanks Even. Anyway to call this organize polygons via the python API as a
> short term fix?
No, C++ "internal" method only.
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you
> must not peruse, use, disseminate, distribute or copy this message. If you
> have received this message in error, please notify us immediately (Phone
> 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
Geospatial professional services
http://even.rouault.free.fr/services.html
