[gdal-dev] gdaltranslate and gdalwarp rotating and resizing image without being asked to, why?
Even Rouault
even.rouault at mines-paris.org
Sat Jun 28 09:01:27 PDT 2014
Jesse,
I'm not completely sure to really understand the axis swapping issue without
reproducing what you do.
The PDF driver should take into account the PDF rotation parameter when
rasterizing it (so that it outputs something that is visually identical with
what other PDF viewers do).
To answer your questions:
1) When not providing an existing target image, gdalwarp will indeed rectify
images that have an arbitrary transform with skew/rotation terms, or GCPs, to
an affine transform with squared pixels, which is generally the desired
behaviour. If you prepare yourself the target dataset with the geotransform
you whish, you should be able run gdalwarp on it. You can alternatively try
the -ts option of gdalwarp to force the target dimensions.
2) The resizing is a consequence of the output geotransform being different
that the source geotransform.
with the SRS and GCP set. However I'd recommand generating a tiled TIFF
instead to make gdalwarp faster.
Best regards,
Even
Le vendredi 27 juin 2014 19:49:35, Jesse McGraw a écrit :
> Gdal gurus,
> I'm writing a utility to automatically georeference Instrument Approach
> Procedures and Airport Diagrams from the FAA (github.com/jlmcgraw, if
> you're curious) and I'm hoping for some insight from the experts here as to
> why I'm seeing the following behavior with Airport Diagrams
> Most of the Airport Diagrams diagrams are portrait orientation (True North
> up), however some of them are actually laid out in landscape orientation
> (True North to the left or right) though the source PDF is still in
> portrait
> If I georeference these landscape oriented using GCPs then gdalwarp will
> swap X and Y axes and also resize the resulting bitmap (it also resizes
> portrait oriented ones too, though without swapping axes)
> My questions:
> 1) Why is gdalwarp swapping the axes rather than using the X and Y
> pixel-skew parameters of the affine transformation (seems to be always 0)?
> 2) Why is it re-sizing the bitmap?
> 3) Do I have to do both of these steps separately (translate and then warp)
> or can I simplify somehow?
> Steps in the process:
> 1) Generate a list of Ground Control Points from the PDF, rasterize the PDF
> to a 300dpi PNG
> 2) gdal_translate .PNG to an intermediate .VRT
> ("gdal_translate -q -of VRT -strict -a_srs EPSG:4326 $gcpstring
> '$targetpng' '$targetvrt'")
> 3) gdalwarp intermediate .VRT to get the final georeferenced output .VRT
> ("gdalwarp -q -of VRT -t_srs EPSG:4326 -order 1 -overwrite ''$targetvrt''
> '$targetvrt2'")
> *example from a landscape diagram*
> (snippet of step 2 output from gdal_translate'd .vrt)
> CA-SFO-00375AD-PDF-AIRPORT-DIAGRAM.vrt:
> *<VRTDataset rasterXSize="1613" rasterYSize="2475">*
> (snippet of step 3 output from gdalwarp'd .vrt)
> warpedCA-SFO-00375AD.PDF-AIRPORT\ DIAGRAM.vrt:
> *<VRTDataset rasterXSize="2623" rasterYSize="1359"
> subClass="VRTWarpedDataset">*
> *<GeoTransform> -1.2242081739746585e+02, 2.9114844968978991e-05,
> 0.0000000000000000e+00, 3.7641622693302779e+01, 0.0000000000000000e+00,
> -2.9114844968978991e-05</GeoTransform>*
> *example from a portrait diagram*
> *VA-RIC-00347AD-PDF-AIRPORT-*
> *DIAGRAM.vrt*
> *warpedVA-RIC-00347AD.PDF-*
> *AIRPORT\ DIAGRAM.vrt*
> *<VRTDataset rasterXSize="1870" rasterYSize="2287"
> subClass="VRTWarpedDataset"><GeoTransform> -7.7341103107298423e+01,
> 2.1580033523515700e-05, 0.0000000000000000e+00, 3.7529840835409082e+01,
> 0.0000000000000000e+00, -2.1580033523515700e-05</GeoTransform>*
> Thanks!
> -Jesse McGraw
Geospatial professional services
http://even.rouault.free.fr/services.html
