[gdal-dev] gdaltranslate and gdalwarp rotating and resizing image without being asked to, why?
Even Rouault even.rouault at mines-paris.org
Mon Jun 30 12:07:58 PDT 2014
Le lundi 30 juin 2014 15:47:41, Jesse McGraw a écrit :
> Even,
>   Thank you for the response!
> I'm actually rasterizing the PDF to PNG via pdftoppm before doing anything
> with gdal*, that's why the rotating and resizing surprises me.
hum ok I though you used the GDAL PDF driver.
> When do the pixelSkew parameters get used vs. swapping the axes?  The
> swapping works in this case is because the rotation is 90 degrees but what
> would happen with an arbitrary rotation (eg 37 degrees).
gdalwarp has no explicit "swap axis" operation. It uses GCP information to
warp the image. swaping might occur if your GCP ask GDAL to do so.
> The reason I'm curious about all this is that I'm wanting to use only the
> initially generated PNG for my final georeferenced image and not have to
> generate an additional one that is rotated by gdal with the skew parameters
> set to 0 and also resized.
> If I can provide any more detail on my process or what I'm trying to
> accomplish please let me know.
> Here's the general flow for Airport Diagrams:
> Source PDF -> create PNG, create list of GCPs from the PDF mapped to that
> PNG ->
That might the problem. If you create the GCPs on the PDF and not on the PNG,
and that the PDF has rotation, pdftoppm I think will apply the rotation, hence
the axis swapping.
Well I'm really confused by what you are trying to do.
For a better understanding, you should perhaps provide the PDF and all exact
command lines you are typing.
> gdal_translate PNG to intermediate VRT -> gdal_warp intermediate VRT
> to final VRT
> The final VRT displays properly in QGIS so the process is working correctly
> but I was hoping to be able to extract from it all of the parameters of the
> affine transformation necessary to properly display the PNG as a
> geoferenced image (origin, extents, pixel sizes and pixel skew) in a
> separate Android application.  (This bitmap is to be used in a separate
> moving map application to display an airplane's real world position on the
> image)
> -Jesse
> On Sat, Jun 28, 2014 at 12:01 PM, Even Rouault
> <even.rouault at mines-paris.org
> > wrote:
> > Jesse,
> > I'm not completely sure to really understand the axis swapping issue
> > without
> > reproducing what you do.
> > The PDF driver should take into account the PDF rotation parameter when
> > rasterizing it (so that it outputs something that is visually identical
> > with
> > what other PDF viewers do).
> > To answer your questions:
> > 1) When not providing an existing target image, gdalwarp will indeed
> > rectify
> > images that have an arbitrary transform with skew/rotation terms, or
> > GCPs, to
> > an affine transform with squared pixels, which is generally the desired
> > behaviour. If you prepare yourself the target dataset with the
> > geotransform you whish, you should be able run gdalwarp on it. You can
> > alternatively try the -ts option of gdalwarp to force the target
> > dimensions.
> > 2) The resizing is a consequence of the output geotransform being
> > different that the source geotransform.
> > 3) You could likely merge your step 1 and 2, i.e. directly generate a
> > .png with the SRS and GCP set. However I'd recommand generating a tiled
> > TIFF instead to make gdalwarp faster.
> > Best regards,
> > Even
> > Le vendredi 27 juin 2014 19:49:35, Jesse McGraw a écrit :
> > > Gdal gurus,
> > > I'm writing a utility to automatically georeference Instrument Approach
> > > Procedures and Airport Diagrams from the FAA (github.com/jlmcgraw, if
> > > you're curious) and I'm hoping for some insight from the experts here
> > > as
> > to
> > > why I'm seeing the following behavior with Airport Diagrams
> > > Most of the Airport Diagrams diagrams are portrait orientation (True
> > North
> > > up), however some of them are actually laid out in landscape
> > > orientation (True North to the left or right) though the source PDF is
> > > still in portrait
> > > If I georeference these landscape oriented using GCPs then gdalwarp
> > > will swap X and Y axes and also resize the resulting bitmap (it also
> > > resizes portrait oriented ones too, though without swapping axes)
> > > My questions:
> > > 1) Why is gdalwarp swapping the axes rather than using the X and Y
> > > pixel-skew parameters of the affine transformation (seems to be always
> > 0)?
> > > 2) Why is it re-sizing the bitmap?
> > > 3) Do I have to do both of these steps separately (translate and then
> > warp)
> > > or can I simplify somehow?
> > > Steps in the process:
> > > 1) Generate a list of Ground Control Points from the PDF, rasterize the
> > PDF
> > > to a 300dpi PNG
> > > 2) gdal_translate .PNG to an intermediate .VRT
> > > ("gdal_translate -q -of VRT -strict -a_srs EPSG:4326 $gcpstring
> > > '$targetpng'  '$targetvrt'")
> > > 3) gdalwarp intermediate .VRT to get the final georeferenced output
> > > .VRT
> > >  ("gdalwarp -q -of VRT -t_srs EPSG:4326 -order 1 -overwrite
> > ''$targetvrt''
> > > '$targetvrt2'")
> > > *example from a landscape diagram*
> > > (snippet of step 2 output from gdal_translate'd .vrt)
> > > CA-SFO-00375AD-PDF-AIRPORT-DIAGRAM.vrt:
> > > *<VRTDataset rasterXSize="1613" rasterYSize="2475">*
> > > (snippet of step 3 output from gdalwarp'd .vrt)
> > > warpedCA-SFO-00375AD.PDF-AIRPORT\ DIAGRAM.vrt:
> > > *<VRTDataset rasterXSize="2623" rasterYSize="1359"
> > > subClass="VRTWarpedDataset">*
> > > *<GeoTransform> -1.2242081739746585e+02,  2.9114844968978991e-05,
> > > 0.0000000000000000e+00,  3.7641622693302779e+01,
> > > 0.0000000000000000e+00, -2.9114844968978991e-05</GeoTransform>*
> > > *example from a portrait diagram*
> > > *VA-RIC-00347AD-PDF-AIRPORT-*
> > > *DIAGRAM.vrt*
> > > *warpedVA-RIC-00347AD.PDF-*
> > > *AIRPORT\ DIAGRAM.vrt*
> > > *<VRTDataset rasterXSize="1870" rasterYSize="2287"
> > > subClass="VRTWarpedDataset"><GeoTransform> -7.7341103107298423e+01,
> > > 2.1580033523515700e-05,  0.0000000000000000e+00,
> > > 3.7529840835409082e+01, 0.0000000000000000e+00,
> > > -2.1580033523515700e-05</GeoTransform>* Thanks!
> > > -Jesse McGraw
> > Geospatial professional services
> > http://even.rouault.free.fr/services.html
