[gdal-dev] Missing features after copying layers from Shapefiles to SQLite
a.furieri at lqt.it
a.furieri at lqt.it
Tue Mar 4 04:42:38 PST 2014
On Tue, 4 Mar 2014 23:13:51 +1100, Nik Sands wrote:
> The conversion process is a little slow for large data sets
Hi Nik,
SQLite is a transactional DBMS and consequently your
approach to transaction handling has a very strong
impact on write performances.
just as a quick and dirty rule-of-the-thumb: performing
a single COMMIT every 64K inserted rows is surely better
than performing 64 distinct COMMITs one every 1K inserted
rows.
an even more aggressive approach: just completely disable
SQLite's journal and transaction support when you are
planning to import a very huge dataset.
you simply have to execute the following PRAGMA directive
before starting your import process:
PRAGMA journal_mode=OFF;
be very careful; completely disabling the journal could
have the very unpleasant consequence that if unhappily
some SQL error occurs during the import your target DB-file
will be quite surely irremediably corrupted.
but this isn't usually a big issue, at least until you
can safely restart the import process from scratch by
creating a brand new empty DB-file.
a further possible optimization; the default SQLite's
cache could be too small to adequately support an huge
number of INSERTs while updating the Spatial Index at
the same time.
in this case explicitly setting a bigger cache usually
have strong performance benefits:
PRAGMA cache_size=-500000;
please note: SQLite intends any *negative* size to
be expressed in KB; so the above directive will cause
SQLite to allocate as much as 500 MB for its cache;
and this will obviously dramatically reduce the number
of physical I/O operations.
bye Sandro
