[gdal-dev] Heuristics to classify raster data ?
Even Rouault even.rouault at mines-paris.org
Fri Mar 7 10:49:49 PST 2014
Le jeudi 06 mars 2014 20:50:45, Joaquim Luis a écrit :
> Even,
> Did not get it all. You want a method that allows you to tell between a
> map and aerial/satellite image?
Yes exactly
> I believe the k-means algorithm would produce quite good results on maps
> as is expectable that individual clusters would have low variance.
Hum, I read a bit http://en.wikipedia.org/wiki/K-means_clustering and not
being familiar with it, it is not obvious how that could lead to the binary
result I expect ;-) I was hoping for a ready-made solution for my problem. I'm
kind of demanding tonight ;-)
Thanks anyway,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
