[gdal-dev] Problem with results on two different versions of gdal_wrap
Even Rouault
even.rouault at mines-paris.org
Sat Mar 8 02:22:35 PST 2014
> This is the problem step:
> gdalwarp -rcs -ts 8800 6600 -s_srs EPSG:32662 -t_srs EPSG:4326 temp.tif
> target.tif
> gdalinfo -mm -stats target.tif
> is showing that the range of values in the image are dramatically
> different on the two servers!
> summary old:
> Band 1 Block=8800x1 Type=Int16, ColorInterp=Gray
> Computed Min/Max=-3877.000,32767.000
> Minimum=-3877.000, Maximum=32767.000, Mean=25235.731, StdDev=10612.642
> summary new:
> Min=-9314.000 Max=32561.000 Computed Min/Max=-9314.000,32561.000
> Minimum=-9314.000, Maximum=32561.000, Mean=19166.800, StdDev=7786.806
> Ok, so you can see that the values are radically different. My question
> is how do I get values like the old system? These values represent
> temperatures and I need to get the same values.
> My one thought on this is that if is another side effrct of proj4
> behaving differently as I had to adjust the position above to get it to
> align. So maybe the gdalwarp is messing up the pixel values when it
> reprojects it also. But I'm totally lost on how make this work correctly.
> Any thoughts on how to fix this?
Stephen,
I think we already had a discussion some time ago about differences between
spherical or ellipsoidal projections, or am I confusing with someone else ?
Well, it is not clear from your experiment if the difference is due to
reprojection or to the resampling method.
There's a difference between both GDAL versions, but is the new result worse
than the previous one (from visual inspection) ?
Cubic spline resampling seems to produce overshoot artifacts in both
situations (since -3877.000 or -9314.000 in output < 377 in input). That's
probably due to the maths behind.
Maybe just try with the default nearest resampling to see if it is due to the
resampling kernel or the reprojection.
I'm also wondering if your data doesn't have a nodata value that you should
explicitely set. As I can only guess, 32767 would be a good candidate given
that the data type is Int16. But the " _FillValue=[65535]" in the metadata
makes me wonder if the datatype shouldn't be UInt16 rather than Int16 in your
initial conversion from netcdf to geotiff, and the nodata would rather be 65535
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
