[gdal-dev] Moving the poles
Laskaris
francisrayder at yahoo.co.uk
Sun Mar 9 10:56:31 PDT 2014
Thank you for your reply. However, I have already tried CDO and it does not
work for what I am trying to do.
When you apply a rotated pole grid to a file with CDO, it does not change
any of the data in the fields. It does not do any kind of "reprojection", as
it were. All it does is add info about the location of the rotated pole to
the file header, and then the file gets displayed accordingly by netcdf file
viewers. Then, when you regrid to a normal, regular lat lon grid, the
rotated pole is removed again from the header, and you are left with the
very same file you started with.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Moving-the-poles-tp5127897p5127937.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
