[gdal-dev] Make stdin in OGR/GDAL tools cross-platform?
Even Rouault
even.rouault at mines-paris.org
Thu Mar 13 03:10:43 PDT 2014
Stefan,
/dev/stdin is indeed Unix specific, but /vsistdin/ is a special filename within
GDAL virtual file system handling. So I believe /vsistdin/ should also work on
Windows, but I'm not sure this has been very much tested. Just try !
Even
> In OSM driver [1] there's an example about using stdin in OGR which is
> Unix based:
> > Reading .osm.bz2 files and/or online files
> > .osm.bz2 are not natively recognized, however you can process them (on
> Unix),
> > with the following command :
> > bzcat my.osm.bz2 | ogr2ogr -f SQLite my.sqlite /vsistdin/
> > You can convert a .osm or .pbf file without downloading it :
> > wget -O - http://www.example.com/some.pbf | ogr2ogr -f SQLite my.sqlite
> /vsistdin/
> Is it possible to do that also under Windows? Like this (untested but
> inspired by [2]!)
> %wget -O - http://www.example.com/some.pbf | ogr2ogr -f SQLite my.sqlite <1
> or
> % type singapore.geojson | ogrinfo -al -so <1
> --Stefan
> [1] http://www.gdal.org/ogr/drv_osm.html
> [2]
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/redirection.mspx?mfr=true
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
