[gdal-dev] Draft GDAL/OGR class hierarchy for GDAL 2.0
Etienne Tourigny
etourigny.dev at gmail.com
Tue Mar 25 12:12:30 PDT 2014
I also (respectfully) think that there are too many classes (mostly the
abstract classes and interfaces) which make it a bit hard to understand.
I like Vincent's second suggestion to have 3 base Dataset classes
(GDALRasterDataset, GDALVectorDataset, GDALHybridDataset) which inherit
from GDALDataset, and an enum (vector,raster,hybrid) to easily query which
type the Dataset is (or which type its driver supports). You then subclass
the relevant Dataset class and it *should* work auto-magically for rasters.
For example, a given Dataset which subclasses GDALDataset would be
migrated as a subclass of GDALRasterDataset, which would imply that it
does not have a vector dataset. If the implementation changes to allow
vector, then you would change its parent and implement relevant vector
methods.
My view on this is KISS with a minimum number of classes...
cheers
Etienne
On Tue, Mar 25, 2014 at 9:13 AM, Vincent Mora <vincent.mora at oslandia.com>wrote:
> On 25/03/2014 11:44, Even Rouault wrote:
>> Selon Vincent Mora <vincent.mora at oslandia.com>:
>> On 24/03/2014 21:46, Even Rouault wrote:
>>>> Hi,
>>>> "Release soon, release early", so for people who like UML diagrams
>>>> (there
>>> is
>>>> also a prototype of C++ classes for those who don't like UML very much),
>>> here's
>>>> a blog entry with the outcome of my thoughts for a possible
>>>> re-organisation
>>> of
>>>> the GDAL/OGR class hierarchy
>>>> http://erouault.blogspot.ca/2014/03/draft-gdalogr-class-
>> hierarchy-for-gdal.html
>>> I don't understand the need for HandleRasterData() and
>>> HandleVectorData().
>>> Isn't inheriting from GDALEmptyRasterDataset or GDALEmptyVectorDataset
>>> sufficient to convey the information that the class doesn't handle those
>>> kind of datasets.
>>> A call to GetLayerCount()/GetRasterCount() from the class user is
>>> sufficient to say "no vector/raster data here", and a dynamic _cast to
>>> GDALEmptyVectorDataset/GDALEmptyRasterDataset is even clearer to me, so
>>> HandleRasterData()/HandleVectorData() would be a third way to tell the
>>> same thing.
>> Actually, when thinking more about this, this kind of information should
>> be at
>> the driver level, and not at the dataset level. The idea is that there
>> are use
>> cases where you want to know if a driver can handle only vector, only
>> raster, or
>> both. For example if you still want to have separate Open dialog boxes for
>> raster or vector.
>>> Also I'm not sure about the names GDALAbstract* since those are partial
>>> implementations.
>> I know I'm not very good at naming. Do you have an alternative proposal ?
>> The
>> issue is that with my draft we end up with a lot of classes and
>> interfaces, so
>> it is not obvious to find a good name to reflect their content.
> Partial sound ok to me, but I not so good at naming ?
> Considering the number of classes, I gave it some thoughts this morning
> and, like Dmitry, thought of merging the Abtract (Partial) into the
> interface before realizing that, even if it works (you can overload de
> default function in Empty) it's a bit ugly and I ended up preferring your
> solution.
> An altenative would be to have a Dataset with both aspects and provide
> three partial specialisations: one for vector (it will behave like empty
> raster) one for raster, and one for both. Code duplications could be
> avoided by implementing protected member functions in the Dataset class and
> simply calling them in the implementations of partial specialization. This
> solution avoid the diamond shaped inheritance diagram of hell :)
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140325/cb611b3f/attachment.html>
