[gdal-dev] Draft GDAL/OGR class hierarchy for GDAL 2.0
Tim Keitt
tkeitt at utexas.edu
Sat Mar 29 09:08:18 PDT 2014
On Fri, Mar 28, 2014 at 3:24 PM, Mateusz Łoskot <mateusz at loskot.net> wrote:
> On 28 March 2014 21:04, Tim Keitt <tkeitt at utexas.edu> wrote:
> > Something to consider is writing an interface that wraps the old code.
> > Modern generic approaches make this easy.
> > Perhaps evaluate the Generic Image Library and Boost Geometry as
> candidates?
> GDAL is I/O oriented, whereas in GIL and BG, I/O layer is an extension.
> Regardless, I've been prototyping GDAL driver for the new GIL I/O
> layer (aka GIL.IOv2),
> you may check it here
> https://github.com/mloskot/boost-gil-workshop/tree/gil-io2-gdal
Looks promising. Certainly a nicer framework for implementing algorithms.
THK
> Best regards,
> Mateusz Łoskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.keittlab.org/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140329/b69c086c/attachment.html>
