[gdal-dev] FileGDB feature datasets
Eric Goddard
egoddard1010 at gmail.com
Fri May 2 12:57:52 PDT 2014
I've been able to open feature classes within datasets, and there is
an option to specify the feature dataset under the layer creation
options (http://www.gdal.org/ogr/drv_filegdb.html). It might be a
custom projection issue -- the FileGDB driver doesn't support custom
projections, and if one is present then none of the features in the
geodatabase can be read. There was a similar post on the QGIS mailing
list: http://osgeo-org.1560.x6.nabble.com/Problem-opening-GDB-v-10-1-using-QGIS-td5131380.html#a5133625
Eric
On Fri, May 2, 2014 at 2:44 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> For a while I've been converting FileGDB v9 files to v10 with Arc (export to GDB multiple) so I can read them with GDAL (1.10). This works fine, the conversion creates a flat GDB, though the original GDB has the data grouped in feature datasets.
> I just got some v10 GDBs, so no conversion needed, right? Nothing is visible with GDAL. They also have data divided into feature datasets within the GDB, so it sounds like GDAL can't acces the dataset groups. Unless I'm missing an option (the GDAL docs for the FileGDB format don't mention datasets)?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
> - the wisdom of Tarzan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
