[gdal-dev] Difficulty opening Safecast GeoJSON data
Mark Coletti
mcoletti at gmail.com
Mon May 5 13:29:13 PDT 2014
Thank you Even and Sean for your very quick and salient replies! I'll
notify the Safecast folks that their data might be better served using
GeoJSON; meanwhile, they also make their open source data available as a
single downloadable file in CSV format. Since qgis can import files of
that type, I've been using that; it's just that I have to do a lot more
work on my end to pare the data down to the region of interest. (And deal
with the inevitable data corruption. E.g., I suspect the observations from
2020 are bogus unless they have a time traveler volunteering radiation
readings. =) )
Again, thank you for your help!
Cheers,
Mark
On Mon, May 5, 2014 at 4:12 PM, Sean Gillies <sean at mapbox.com> wrote:
> Hi Mark,
> Safecast's JSON isn't GeoJSON, but wouldn't be too hard to crosswalk over
> to GeoJSON... make a geometry from its latitude/longitude, stuff all the
> other attributes in properties.
> On 5/5/14, 1:56 PM, Mark Coletti wrote:
>> Safecast is user sourced radiation data, and has a public API serving
>> data in GeoJSON format (https://api.safecast.org/en-US/home). However,
>> I'm having difficulty in accessing this data via OGR:
>> % ogrinfo -so
>> "https://api.safecast.org/en-US/measurements?distance=10&
>> latitude=37.42&longitude=141.033"
>> ERROR 4: Failed to read GeoJSON data
>> FAILURE:
>> Unable to open datasource
>> `https://api.safecast.org/measurements.json?distance=10&
>> latitude=37.42&longitude=141.033'
>> with the following drivers.
>> So OGR sees that the data is formatted as GeoJSON, but is unable to read
>> it for some reason.
>> Using curl to manually make the query I get:
>> % curl -i -H "Accept: application/json"
>> HTTP/1.1 200 OK
>> Server: nginx
>> Date: Mon, 05 May 2014 19:43:55 GMT
>> Content-Type: application/json; charset=utf-8
>> Transfer-Encoding: chunked
>> Connection: keep-alive
>> Status: 200 OK
>> Strict-Transport-Security: max-age=31536000
>> Access-Control-Allow-Origin: safecast.org <http://safecast.org>
>> Access-Control-Allow-Methods: POST, GET, OPTIONS
>> Access-Control-Allow-Headers: *, X-Requested-With
>> Access-Control-Max-Age: 100000
>> X-UA-Compatible: IE=Edge,chrome=1
>> ETag: "e4650539a53d3698d8deb02e912b9ae3"
>> Cache-Control: max-age=0, private, must-revalidate
>> X-Request-Id: a30a38247c16374a39ada0a8d4d2fcde
>> X-Runtime: 0.022855
>> X-Rack-Cache: miss
>> X-Powered-By: cloud66
>> [{"captured_at":"2014-01-30T05:03:25Z","device_id":
>> null,"id":30981293,"location_name":null,"original_id":null,
>> "unit":"cpm","user_id":3,"value":4675.0,"latitude":37.
>> 41997666666666,"longitude":141.03297166666667},{"
>> captured_at":"2014-01-30T05:25:26Z","device_id":null,"id":
>> 30981556,"location_name":null,"original_id":null,"unit":"
>> cpm","user_id":3,"value":2470.0,"latitude":37.42001666666667,"longitude":
>> 141.03303666666667},{"captured_at":"2014-01-30T05:
>> 00:54Z","device_id":null,"id":30981263,"location_name":null,
>> "original_id":null,"unit":"cpm","user_id":3,"value":5428.0,"latitude":37.
>> 41996666666667,"longitude":141.03301666666667},{"
>> captured_at":"2014-01-30T05:21:20Z","device_id":null,"id":
>> 30981507,"location_name":null,"original_id":null,"unit":"
>> cpm","user_id":3,"value":12191.0,"latitude":37.
>> 420003333333334,"longitude":141.03305333333333},{"
>> captured_at":"2014-01-30T05:00:49Z","device_id":null,"id":
>> 30981262,"location_name":null,"original_id":null,"unit":"
>> cpm","user_id":3,"value":5199.0,"lat
> i
> tude":37.41999666666667,"longitude":141.03306166666667}
> ,{"captured_at":"2014-01-30T05:25:21Z","device_id":
> null,"id":30981555,"location_name":null,"original_id":null,
> "unit":"cpm","user_id":3,"value":2423.0,"latitude":37.
> 42006833333333,"longitude":141.03301333333334},{"
> captured_at":"2014-01-30T05:03:30Z","device_id":null,"id":
> 30981294,"location_name":null,"original_id":null,"unit":"
> cpm","user_id":3,"value":4456.0,"latitude":37.41992833333333,"longitude":
> 141.03297333333333},{"captured_at":"2014-01-30T05:
> 00:59Z","device_id":null,"id":30981264,"location_name":null,
> "original_id":null,"unit":"cpm","user_id":3,"value":5672.0,"latitude":37.
> 419963333333335,"longitude":141.03291666666667},{"
> captured_at":"2014-01-30T05:00:44Z","device_id":null,"id":
> 30981261,"location_name":null,"original_id":null,"unit":"
> cpm","user_id":3,"value":5135.0,"latitude":37.420035,"
> longitude":141.03309},{"captured_at":"2014-01-30T05:
> 21:14Z","device_id":null,"id":30981506,"location_name":null,
> p
> m","user_id":3,"value":12164.0,"latitude":37.42006333333333,"longitude":
> 141.03293666666667}]
>> Those do look like legitimate observations, but I don't know if they
>> comply to the GeoJSON format since I'm new to JSON.
>> I'm using this version of GDAL/OGR, which was part of the pre-packaged
>> binaries for qgis for my Mac:
>> % ogrinfo --version
>> GDAL 1.10.1, released 2013/08/26
>> Eventually I'd like to use GDAL/OGR to conveniently create a local
>> spatial database from such a query. However, I need to get over this
>> hurdle first.
>> Cheers,
>> Mark
>> mcoletti at gmail.com <mailto:mcoletti at gmail.com>
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sean Gillies
> sean at mapbox.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140505/99107e05/attachment-0001.html>
