[gdal-dev] ogr2ogr error handling
scottm361 scottm361 at gmail.com
Wed May 7 15:54:50 PDT 2014
Hi Even
Thanks for the reply.
the command I am using does use clipping, but not spatial filtering:
gdal\apps\ogr2ogr.exe -overwrite -t_srs
"layers\NFI_MODIS250m_kNN_Structure_Stand_Age_v0.prj" -clipdst  -2600000
5700000 3100000 10500000 -skipfailures
".\temp\nfdb_poly_20111223_21094F1A58AE467E\nfdb_poly_20111223_21094F1A58AE467E.shp"
"layers\fire\nfdb_poly_20111223.shp"
Is there an alternative way to do this that I should use?
Scott
View this message in context: http://osgeo-org.1560.x6.nabble.com/ogr2ogr-error-handling-tp5139067p5139115.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
