[gdal-dev] VRT ComputeStatistics fails because of self-reference
Matt Gregory matt.gregory at oregonstate.edu
Tue May 13 14:36:49 PDT 2014
Hi all,
I'm trying to compute statistics on a VRT file using the python
band.ComputeStatistics method.  I'm using GDAL 1.10.1 on a Windows 7
64-bit box.
First, I create a VRT clip of a larger raster using gdal_translate, e.g.
   gdal_translate -of VRT -projwin <sub_window> in.tif out.vrt
Then, in Python, I try to compute statistics:
   ds = gdal.OpenShared('out.vrt', gdalconst.GA_ReadOnly)
   rb = ds.GetRasterBand(1)
   (min, max, mean, std) = rb.ComputeStatistics(False)
This fails with many messages of:
   ERROR 1: VRTSourcedRasterBand::IRasterIO() called recursively on
     the same band.
   It looks like the VRT is referencing itself.
   ERROR 1: test.vrt, band 29: IReadBlock failed at X offset 1, Y
     offset 3
I can replicate the same behavior by first creating the VRT using
gdal_translate and then calling gdalinfo -stats on it.
I see in the code that I'm triggering the bAntiRecursionFlag within the
GetMinimum and GetMaximum member functions, but unclear how this is
coming about.
thanks for help,
matt
