[gdal-dev] Update of EPSG database to v8.4
Peter Baumann
p.baumann at jacobs-university.de
Thu May 15 14:43:16 PDT 2014
I've been talking to OGP folks, and they were not really interested - BTW, also
not in our time coordinate reference systems; Time CRSs are being addressed
within OGC, therefore: the OGC resolver serves space and (soon) time, and
spatial requests will be forwarded to the EPSG service.
On including planetary CRSs in the OGC service we are talking with several
people (inlc USGS, who likes the idea), but we decided to first get through with
time before pursuing planetary stuff further.
OGC's CRS resolver (which we have implemented in FOSS) definitely allows such a
scope extension.
cheers,
Peter
On 05/15/2014 01:50 PM, Even Rouault wrote:
> Selon Yann Chemin <ychemin at gmail.com>:
>> Hi,
>> is there planetary datum support in this new version (i.e. Moon 2000, or
>> etc.)?
> No, I don't think that the EPSG folks are interested in other planets yet ;-)
> But Frank mentionned some time ago (
> http://osgeo-org.1560.x6.nabble.com/IAU-2000-Coordinate-System-Dictionary-td3750798.html
> ) that he wanted to investigate how to deliver the IAU set of planetary
> coordinate systems , but this hasn't been pursued further AFAIK.
> I see there's a version of this file here :
> http://svn.osgeo.org/metacrs/sr.org/srsbrowser/data/IAU2000.wkt
> Even
>> Yann
>> On 14/05/2014, Even Rouault <even.rouault at mines-paris.org> wrote:
>>> Hi,
>>> I've followed the update process of the EPSG SRS database to latest v8.4,
>>> and
>>> just committed the updated files into libgeotiff, GDAL and PROJ trunk. Also
>>> submitted to PostGIS.
>>> From what I can see, among many changes and additions, 2 new projection
>>> methods have been added:
>>> * 1051,Lambert Conic Conformal (2SP Michigan)
>>> --> looks very close to standard "Lambert Conic Conformal (2SP)", with the
>>> addition of a new parameter K, the ellipsoid scaling factor.
>>> * 1052,Colombia Urban
>>> I don't think any of those 2 new methods are currently handled by PROJ, so
>>> the
>>> new PCS based on those projection methods (3 Michigan SRS, and several
>>> dozains
>>> of Colombia PCS) will not be handled by GDAL nor PROJ.
>>> Regarding GDAL, I've improved the add_esri_column.py script (see
>>> http://trac.osgeo.org/geotiff/changeset/2446), so that we have more ESRI
>>> DATUM
>>> names. That should make morphing from/to ESRI .prj files a bit better.
>>> Regarding PROJ.4 'espg' and PostGIS spatial_ref_sys.sql files, I've also
>>> added
>>> the list of SRS that are GEOCCS (GeoCentric) and COMPD_CS (Compound
>>> Horizontal
>>> + Vertical).
>>> Please let me know if you see issues.
>>> libgeotiff:
>>> http://trac.osgeo.org/geotiff/ticket/63
>>> http://trac.osgeo.org/geotiff/changeset/2447
>>> GDAL:
>>> http://trac.osgeo.org/gdal/ticket/5462
>>> http://trac.osgeo.org/gdal/changeset/27322
>>> PROJ:
>>> http://trac.osgeo.org/proj/ticket/236
>>> http://trac.osgeo.org/proj/changeset/2448
>>> Submitted for PostGIS :
>>> http://trac.osgeo.org/postgis/ticket/2737
>>> Best regards,
>>> Even
>>> Geospatial professional services
>>> http://even.rouault.free.fr/services.html
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Dr. Peter Baumann
- Professor of Computer Science, Jacobs University Bremen
www.faculty.jacobs-university.de/pbaumann
mail: p.baumann at jacobs-university.de
tel: +49-421-200-3178, fax: +49-421-200-493178
- Executive Director, rasdaman GmbH Bremen (HRB 26793)
www.rasdaman.com, mail: baumann at rasdaman.com
tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis
dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec
preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
