[gdal-dev] New OGR Driver for MongoDB
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri May 23 05:36:43 PDT 2014
Hi Shuai,
Would you be willing to outline your MongoDB build steps on a new page
in the BuildHints wiki? (in section "External Library Issues"
http://trac.osgeo.org/gdal/wiki/BuildHints). That way everyone can
follow your steps and they are not lost in the email archives.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2014-05-22, 7:46 PM, Zhang, Shuai wrote:
> Hey Nicol,
> you are right, you should put the folder in the 'ogr/ogrsf_frmts' directory .
> But the parameters set to compile the driver into gdal/ogr can be a little bit complicated.
> You could find some clues on "OGR Driver Implementation Tutorial",
> but you still need to handle the mongodb lib things.
> if you do not want to bother, attached are a version which could run on windows platform.
> in the nmake.opt file, set MONGO Library to your path. i think it will work.
> just let me know.
> and sorry I haven't make everything ready to use.
> yours,
> shuai
> ________________________________________
> From: Nicol Hermann [mapserver at geoworld.de]
> Sent: Wednesday, May 21, 2014 3:08 PM
> To: Zhang, Shuai
> Subject: Re: [gdal-dev] New OGR Driver for MongoDB
> Hello shuai,
> me again.
> I checked out the Mongo driver from the Git repository but have some
> trouble which steps are necessary to include it into the GDAL trunk.
> Can you please provide me some hints.
> I assume I have to copy the 'mongo' directory to 'ogr/ogrsf_frmts',
> right?
> Anything to consider to have it available as 'configure' option?
> Thanks for your assistance
> Nicol
> Am Montag, den 19.05.2014, 21:12 +0000 schrieb Zhang, Shuai:
>> Hi Nicol,
>> Great you are interested.
>> I opened up a ticket for this project, as you may find here: http://trac.osgeo.org/gdal/ticket/5453
>> you may also find the source code in my github https://github.com/geosky/mongodb-gdal-driver
>> glad if you could join in the mongogis group i set up in the github, we may have some discusses there.
>> thanks,
>> shuai
>> Sent: Monday, May 19, 2014 12:22 PM
>> To: Zhang, Shuai
>> Hello Shuai,
>> I saw your post about the Mongo driver in the GDAL mailing list.
>> Is the driver you wrote for OGR already available somewhere?
>> Did you open up a ticket like Kyle recommended?
>> If so it would be great if you could share the ticket number with me.
>> Thank you very much.
>> Nicol
>> Am Mittwoch, den 30.04.2014, 13:55 +0000 schrieb Zhang, Shuai:
>>> Hi there,
>>> I wrote a ogr driver for mongodb and wish to contribute to the
>>> community.
>>> but I'm not sure where to start and how to do it.
>>> Is there anyone who can give me a hand or some guidance about it?
>>> it will be terrific if you know geojson driver or couchdb driver
>>> well,
>>> so that we may have discussions on the code level.
>>> Thanks,
>>> Shuai
