[gdal-dev] Segmentation fault when using GDALReprojectImage
Gordon Farquharson
gordonfarquharson at gmail.com
Sat May 24 15:53:35 PDT 2014
I am trying to warp a dataset read with the DTED driver by using
GDALReprojectImage. The output dataset is created with the MEM driver. The
program is failing with a segmentation fault. Below is a minimal working
program that shows the error, and the resulting output when run in GDB.
#include <iostream>
#include <string>
#include <gdal/gdal_priv.h>
#include <gdal/gdal_alg.h>
#include <gdal/gdalwarper.h>
#include <gdal/ogr_spatialref.h>
#include <gdal/cpl_conv.h>
#include <gdal/cpl_minixml.h>
namespace {
const size_t SUCCESS = 0;
const size_t ERROR_IN_COMMAND_LINE = 1;
const size_t ERROR_IN_GDAL = 2;
const size_t ERROR_UNHANDLED_EXCEPTION = 3;
void OGRCheckError(OGRErr errnum, const char *errstr)
if (errnum != OGRERR_NONE) {
std::cout << errstr << " (" << errnum << ")" << std::endl;
exit(ERROR_IN_GDAL);
void CPLCheckError(CPLErr errnum)
if (errnum == CE_Failure) {
std::cerr << CPLGetLastErrorMsg() << std::endl;
int main(int argc, char **argv)
try {
std::string pszFilename = "/mnt/raid/dted/w078/n34.dt2";
OGRErr nOGRError;
CPLErr eCPLError;
GDALAllRegister();
// GDAL: opening the input file
GDALDataset *poSrcDataset;
poSrcDataset = (GDALDataset *)GDALOpen(pszFilename.c_str(),
GA_ReadOnly);
if (poSrcDataset == NULL) {
return ERROR_IN_GDAL;
// GDAL: warp data
GDALDatasetH hSrcDataset = poSrcDataset;
GDALDatasetH hDstDataset;
GDALDriverH hDstDriver;
const char *pszDstProj4 = "+proj=utm +zone=11 +datum=WGS84";
const char *pszSrcWKT = poSrcDataset->GetProjectionRef();
char *pszDstWKT = NULL;
OGRSpatialReference oSRS;
double adfDstGeoTransform[6];
int nPixels = 0, nLines = 0;
nOGRError = oSRS.importFromProj4(pszDstProj4);
OGRCheckError(nOGRError, "Error importing proj4 string");
nOGRError = oSRS.exportToWkt(&pszDstWKT);
OGRCheckError(nOGRError, "Error converting proj4 string to WKT");
void *hTransformArg;
hTransformArg =
GDALCreateGenImgProjTransformer(hSrcDataset, pszSrcWKT,
NULL, pszDstWKT,
FALSE, 0, 1);
if (hTransformArg == NULL) {
eCPLError = GDALSuggestedWarpOutput(hSrcDataset,
GDALGenImgProjTransform,
hTransformArg,
adfDstGeoTransform,
&nPixels, &nLines );
CPLCheckError(eCPLError);
// Construct destination Dataset
std::cout << "Constructing output dataset" << std::endl;
GDALDataset *poDstDataset;
poDstDataset = GetGDALDriverManager()->
GetDriverByName("MEM")->
Create("", nPixels, nLines,
poSrcDataset->GetRasterCount(),
poSrcDataset->GetRasterBand(1)->GetRasterDataType(),
NULL);
if (poDstDataset == NULL) {
poDstDataset->SetProjection(pszDstWKT);
poDstDataset->SetGeoTransform(adfDstGeoTransform);
// Warp data
std::cout << "Reprojecting image" << std::endl;
eCPLError = GDALReprojectImage(hSrcDataset, pszSrcWKT,
hDstDataset, pszDstWKT,
GRA_Bilinear,
0.0, 0.0,
GDALTermProgress, NULL,
NULL);
catch(std::exception& e) {
std::cerr << "Unhandled Exception reached the top of main: "
<< e.what() << ", application will now exit" << std::endl;
return ERROR_UNHANDLED_EXCEPTION;
return SUCCESS;
The output in GDB is:
Starting program: /home/gordon/src/novcs/gdal-test/gdal-test-mwp
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Reprojecting image
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7628a4c in GDALGetGeoTransform () from /usr/lib/libgdal.so.1
The program is compiled with
g++ -g gdal-test-mwp.cc -lgdal -Bshared -o gdal-test-mwp
I using the Debian Wheezy GDAL package:
Desired=Unknown/Install/Remove/Purge/Hold
Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii libgdal1 1.9.0-3.1 amd64 Geospatial Data Abstraction
Libra
Anybody got any ideas why this is failing?
Gordon
Gordon Farquharson
GnuPG Key ID: 32D6D676
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140524/7c5012ea/attachment-0001.html>
