[gdal-dev] problems with merging ecw files
Chrishelring
christianhelring at gmail.com
Mon May 26 23:28:41 PDT 2014
hi,
I´m trying to merge about 40 ecw files into one, using gdal_merge.py. it
seems to work (no error), but when I´m trying to open the file, it says,
"Unable to read header information: Cannot open file
c:\temp\ortofoto2007\ortofoto2007.ecw".
I´m using GDAL 1.11.0 with the following command:
C:\TEMP\ortofoto2007>python C:\osgeo4w\bin\gdal_merge.py -o
\ortofoto2007.ecw --optfile c:\temp\ortofoto2007\orto07.txt
Any help would really be appreciated. :)
Christian
View this message in context: http://osgeo-org.1560.x6.nabble.com/problems-with-merging-ecw-files-tp5142634.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
