[gdal-dev] AREA_OR_POINT vs GDALMD_AREA_OR_POINT
Even Rouault even.rouault at mines-paris.org
Thu May 29 14:50:51 PDT 2014
On Thursday 29 May 2014 22:48:04 Joaquim Luis wrote:
> On 29-05-2014 22:08, Even Rouault wrote:
> > > Glad to not do, but than I'm left with nothing. If I do instead as
> > you say
> > > GDALSetMetadataItem(hDstDS, GDALMD_AREA_OR_POINT, "Point", NULL);
> > > which than equivalent to
> > > GDALSetMetadataItem(hDstDS, "AREA_OR_POINT", "Point", NULL);
> > > than, as I showed before and contrary to your python examples, the
> > > GDALSetMetadataItem() is not working in our code.
> > > > On which dataset do you this : a GTiff dataset ? Opened in update
> > mode ?
> > > No, not update mode. It's dataset filled an empty MEM. See (lines #167
> > > and after)
> > http://gmtrac.soest.hawaii.edu/projects/gmt/repository/entry/branches/5.2.
> > 0/>
> > > src/gmt_gdalwrite.c
> > Well, I suppose that your local copy of the code use
> > GDALMD_ARE_OR_POINT unquoted...
> as mentioned before, with and without.
> > I've tried a simplified version of your code and it works for me. Do
> > you use a recent enough version of GDAL ?
> Yes. A svn revision after 1.11.
> > Note: for AREA_OR_POINT to be taken into account in GeoTiff, you need
> > to define both a geotransform and a SRS.
> AHHHHHH. This changes the whole story. Some cases do not set a SRS. Is
> there any fall-back SRS that I could use when no info is available to
> create one?
> Type, 'linear in unknown units'?
I've successfully tried with :
mem_ds.SetProjection('LOCAL_CS["Unknown"]')
Geospatial professional services
http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140529/f021e183/attachment.html>
