[gdal-dev] new landsat-8 metadata format
Daniel Testa danieltesta at suremptec.com.ar
Fri May 30 13:27:32 PDT 2014
Hi, I created a new ticket (http://trac.osgeo.org/gdal/ticket/5501) with a
patch that adds support for the new landsat-8 metadata format.
I've followed the path of HDF5 as Even suggested.
Any idea, suggestion or comment is always very welcome :)
Thanks.
Best regards,
Daniel.
On Sat, May 17, 2014 at 11:06 AM, Daniel Testa <danieltesta at suremptec.com.ar
> wrote:
> > You could have the dataset report subdataset names, like
> > "LANDSAT8:LC82300942013289LGN00_MTL.txt:panchromatic",
> > "LANDSAT8:LC82300942013289LGN00_MTL.txt:multispectral", etc... And when
> those
> > names are passed to the Open() methods would return a dataset that would
> point
> > to the relevant tif.
> I see what you mean. I'll try following that path and let you know how it
> goes.
> Thanks Even.
> Best regards,
> Daniel.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140530/b977bbf8/attachment.html>
