[gdal-dev] Call for discussion on RFC 49: Curve geometries
Even Rouault
even.rouault at spatialys.com
Wed Nov 5 07:01:58 PST 2014
This is a call for discussion on RFC 49: Curve geometries
http://trac.osgeo.org/gdal/wiki/rfc49_curve_geometries
Below the summary :
The current geometry model in GDAL 1.X makes use of points, lines, polygons
and aggregations of them (multipoints, multilines, multipolygons and geometry
collections). It was modeled from the geometry class hierarchy of the
"OpenGIS Simple Feature Access Part 1 : Common Architecture" (in its 1.1.0
version).
This RFC covers the addition of new geometry types that have been added in
ISO/IEC 13249 Part 3 Spatial (abreviated as ISO SQL/MM Part 3):
* circular string: a circular arc, or a sequence of connected circular arcs,
each of them describe by 3 points: the first point of the arc, an
intermediate point and the final point
* compound curve: a sequence of connected curves, either line strings or
circular strings
* curve polygon: polygon consisting of one outer ring, and zero or more
inner ring. Each ring can be one of the curve implementations: line
strings, circular strings, compound curves.
* multicurve: a collection of curves (line strings, circular strings,
compound curves)
* multisurface: a collection of surfaces (polygons, curve polygons)
The scope of this RFC consists in :
* adding the new geometry classes to the existing geometry class hierarchy,
with the corresponding importer and exporter of WKT (Well Known Text) and
WKB (Well Known Binary) encodings
* adding methods to convert those curve geometries into their approximated
linear version, and to do the reverse operation
* upgrading some of the drivers that can support such geometries : GML (and
indirectly NAS, WFS), PostGIS/PGDump, GeoPackage, SQLite, CSV, VRT.
Have a good reading,
Even
http://www.spatialys.com
