[gdal-dev] Can GDAL Access Raster File Stored as Blob in SQLite3 Database?
Jema Bingham
jemabingham at gmail.com
Thu Nov 6 09:14:03 PST 2014
Ahah! You have to add the raster table name then to the command. The
Rasterlite documentation should be updated to reflect this example as it
now misleadingly does not. See below...
Thank you much!
Examples:
- Accessing a rasterlite DB with a single raster table :
$ gdalinfo rasterlitedb.sqlite -noct
Output:
Driver: Rasterlite/Rasterlite
Files: rasterlitedb.sqlite
Size is 7200, 7200
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
Origin = (-5.000000000000000,55.000000000000000)
Pixel Size = (0.002083333333333,-0.002083333333333)
Metadata:
TILE_FORMAT=GIF
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( -5.0000000, 55.0000000) ( 5d 0'0.00"W, 55d 0'0.00"N)
Lower Left ( -5.0000000, 40.0000000) ( 5d 0'0.00"W, 40d 0'0.00"N)
Upper Right ( 10.0000000, 55.0000000) ( 10d 0'0.00"E, 55d 0'0.00"N)
Lower Right ( 10.0000000, 40.0000000) ( 10d 0'0.00"E, 40d 0'0.00"N)
Center ( 2.5000000, 47.5000000) ( 2d30'0.00"E, 47d30'0.00"N)
Band 1 Block=480x480 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
- Listing a multi-raster table DB :
$ gdalinfo multirasterdb.sqlite
Output:
Files:
Size is 512, 512
Coordinate System is `'
Subdatasets:
SUBDATASET_1_NAME=RASTERLITE:multirasterdb.sqlite,table=raster1
SUBDATASET_1_DESC=RASTERLITE:multirasterdb.sqlite,table=raster1
SUBDATASET_2_NAME=RASTERLITE:multirasterdb.sqlite,table=raster2
SUBDATASET_2_DESC=RASTERLITE:multirasterdb.sqlite,table=raster2
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141106/ded1ce59/attachment.html>
