[gdal-dev] What's up with the 8859 encoding?
Even Rouault
even.rouault at spatialys.com
Fri Nov 7 15:08:18 PST 2014
Le samedi 08 novembre 2014 00:03:22, Roger André a écrit :
> Even,
> Thank you for the quick reply. And it appears that using a .CPG file does
> not make a difference in this. Is that correct?
You have to realize that the input and output side of ogr2ogr are completely
isolated from each other.
So if your input shapefile has a .cpg, the shapefile driver will use it to
recode from the input dbf encoding mentionned in the .cpf to UTF-8 which is
the pivot encoding of OGR (if the .cpg indicates UTF-8 then no recoding
occurs)
If the output is a shapefile and you specify -lco ENCODING=UTF-8, as the pivot
encoding of OGR is UTF-8, no recoding will occur and an output .cpg file
indicating UTF-8 will be generated.
> Roger
> On Fri, Nov 7, 2014 at 3:00 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Le vendredi 07 novembre 2014 23:53:09, Roger André a écrit :
> > > Hello List,
> > > I am very curious why after installing GDAL 1.11, I now need to use the
> > > -lco ENCODING=UTF-8 option when using ogr2ogr on any of my already
> > > UTF-8 encoded shapefiles? Failure to do so results in this error,
> > > Warning 1: One or several characters couldn't be converted correctly
> > > from UTF-8 to ISO-8859-1.
> > Roger,
> > The default encoding of shapefiles is ISO-8859-1. So if you don't specify
> > -lco
> > ENCODING=UTF-8, the shapefile driver will attempt to recode from UTF-8 to
> > ISO-8859-1. This behaviour has been introduced in GDAL 1.9. Previously no
> > transcoding was done, and there could be mismatch between the actual
> > encoding
> > of the content and the declared encoding of the DBF.
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
