[gdal-dev] Error with using GML with Python
Pekka Sarkola
pekka.sarkola at gispo.fi
Sun Nov 9 11:55:09 PST 2014
Hi Even,
Thanks about help!
Yes, it seems that my python script use older version of GDAL (1.10.1). I
didn't check that: I thought that even FeatureCount won't work in older
version.
So I need check how to be sure that right version of ogr is loaded. PATH
settings etc. boring ;-)
Rgs,
Pekka
--- Pekka Sarkola - pekka.sarkola at gispo.fi - www.paikkatieto.com ---
-----Alkuperäinen viesti-----
Lähettäjä: Even Rouault [mailto:even.rouault at spatialys.com]
Lähetetty: 9. marraskuuta 2014 21:27
Vastaanottaja: gdal-dev at lists.osgeo.org; Pekka.Sarkola at gispo.fi
Aihe: Re: [gdal-dev] Error with using GML with Python
Le dimanche 09 novembre 2014 18:28:13, Pekka Sarkola a écrit :
> Hi,
> I might have newbie problem with OGRs GML driver in Python.
> I try to read GML files with Python script, but wont get access to
> features. I tried this on Window (ogr version 1.11.1), unfortunately I
> couldnt check this in other enviroments, yet.
> So my sample testing script result is
> Loop aita layer...
> Count of features: 181
> None
> None
> Start Loop...
> End of Loop
> And sample script is very simple:
> #!/usr/bin/python
> # -- Start of test script ---
> import sys;
> from osgeo import ogr;
> driver = ogr.GetDriverByName('GML');
> if driver is None:
> print "Error with driver"
> sys.exit(1)
> fn = '<your path>/L4131R.xml'
> #fn = '/data/nlsfi/MTK-GML/L34131R.xml'
> datasrc=driver.Open(fn,0);
> if datasrc is None:
> print "Error opening " + fn;
> sys.exit(1);
> print "Loop aita layer..."
> myLayer=datasrc.GetLayer("Aita")
> print " Count of features: "+str(myLayer.GetFeatureCount())
> print myLayer.GetNextFeature();
> print myLayer.GetFeature(2);
> print "Start Loop..."
> for feat in myLayer:
> print "a"
> print "End of Loop"
> # -- End of test script ---
> GML file is National Land Survey of Finland's special GML. I can
> access with ogrinfo and other command line tools, but not from Python
> (version 2.7.3). You can download sample datasets from Kapsi, example
> http://kartat.kapsi.fi/files/maastotietokanta/kaikki/etrs89/gml/L4/L41
Pekka,
I cannot reproduce such a behaviour neither on Linux nor on Windows. Are you
sure that the GDAL Python bindings you use are GDAL 1.11.1 ?
Try:
from osgeo import gdal
gdal.VersionInfo('')
You could also try with another datasource, like shapefile, etc.. to see if
you see a similar issue.
Even
> Any help is appreciated. I try to check this also in Ubuntu, but
> currently I don't have working environment for GDAL 1.11.1. So if
> somebody can test this on Ubuntu 14.04 (or any other version above
> 12.04)
> Rgs,
> Pekka
> Pekka Sarkola
> Gispo Oy
> pekka.sarkola at gispo.fi - GSM +358 40 725 2042
> www.gispo.fi www.paikkatieto.com
> gdal-dev mailing list
Spatialys - Geospatial professional services http://www.spatialys.com
