[gdal-dev] Associate single point coordinates to image.
Eli Adam
eadam at co.lincoln.or.us
Fri Nov 14 09:06:58 PST 2014
I think that this is generally call "geotagging" which might help
while looking for options.
Eli
On Fri, Nov 14, 2014 at 9:03 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> GDAL reads EXIF data and you can grab that output and then send it
> into an OGR output. I used to have a bash script that did that, but
> then I found there were some tricky things to overcome and found that
> GpsPrune is really good at this.
> GpsPrune can also correlate a GPS track and time stamped photos
> lacking EXIF location data. It exports KML points for the photos.
> ExifTool has lots of EXIF data manipulation capacity,
> http://www.sno.phy.queensu.ca/~phil/exiftool/
> Best regards, Eli
> On Fri, Nov 14, 2014 at 3:38 AM, deve <orante.tucceri at exprivia.it> wrote:
>> Yes. The final effect is the same: photo--> location-->image over the map.
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/Associate-single-point-coordinates-to-image-tp5172985p5173000.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
