[gdal-dev] a postgis table to another
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Nov 16 06:32:24 PST 2014
On 11/16/2014 8:01 AM, Ahmet Temiz wrote:
> Hello
> Is it possible to export (CREATE )a postgis table to another in
> different projection?
> regards
There are a few ways that I can think of to do this:
1. add another column to the table with the project you want. Then
export using that column, maybe using a view.
2. just define a view the does the reprojection to what you want and
export that.
select st_addgeometrycolumn("mytable", "geom_4326", 2,
"MULTILINESTRING", 4326);
update mytable set geom_4326=st_transform(geom, 4325);
pgsql2shp ... -g geom_4326 mydb mytable -f outfile.shp
create view table_4326 as select ..., st_transform(geom, 4326) as geom;
pgsql2shp ... -f outfile.shp table_4326
3. you can export a table using a SQL command and you couls do the
reprojection using that.
pgsql2shp ... -f outfile.shp "select ..., st_transform(geom, 4326) as geom"
-Steve
