[gdal-dev] Interlis driver does not polygonize anymore
Stefan Ziegler stefan.ziegler.de at gmail.com
Mon Nov 17 05:31:23 PST 2014
Perfect! Thanks.
Did I get it right: If I want the polygon from an "AREA"-table I need to
explicit request the polygon geometry? From my point of view the point
geometry from an "AREA"-table is only there to join the attributes to the
polygons.
regards
Stefan
On Mon, Nov 17, 2014 at 8:52 AM, Pirmin Kalberer <pi_ml at sourcepole.com>
wrote:
> Hi Stefan,
> Am Freitag, 14. November 2014, 17.09:12 schrieb Stefan Ziegler:
> > Ok, the autotest example runs smoothly. It seems a problem with the order
> > of the relation attribute "Entstehung" in the table
> > Bodenbedeckung__BoFlaeche in my data (find it attached). It is added as
> the
> > last attribute in the table but actually it's the second one (after TID).
> > I remember that the order of these relation attributes are a bit nasty to
> > handle. Pirmin, can you confirm this behaviour/bug? I guess this was
> > introduced with the change from ili (java) to imd?
> This bug has been fixed in trunk about 3 weeks ago. The imd file has to be
> generated with ili2c.jar >=4.5.5 from the sourceforge site (not available
> on
> interlis.ch).
> Regards
> Pirmin
> > On Fri, Nov 14, 2014 at 3:23 PM, Even Rouault <
> even.rouault at spatialys.com>
> > wrote:
> > > Stefan,
> > > > I've got some problems with the interlis driver. When I try to
> convert
> > > > an
> > > > interlis 1 file to shapefiles with the following command:
> > > > ogr2ogr shpdir/ 254900/254900.itf,dm01avso24.imd
> > > > There are no polygon shapes created. It seems that the point
> coordinates
> > > > which are stored in two separate columns - are shifted.
> > > The driver now supports multiple geometry columns since GDAL 1.11. On
> the
> > > example in the GDAL autotest, it appears that the point geometry
> column is
> > > declared before the second geometry column, so
> > > you'll get only the point when translating to shapefile, unless you
> > > explicitely specify the polygon geometry column (look at its name with
> > > ogrinfo)
> > > With the sample in autotest :
> > > ogr2ogr out.shp data/ili/Beispiel.itf,data/ili/Beispiel.imd
> > > Bodenbedeckung__BoFlaechen -overwrite -select Form
> > > > Column "Geometrie_" contains a small double value. Column
> "Geometrie_1"
> > > > contains one coordinate. Column "Qualitaet" contains the second
> > > coordinate.
> > > Not sure about that. Maybe Pirmin has an idea. A sample dataset of
> yours
> > > might be needed.
> > > Even
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
> Pirmin Kalberer
> Sourcepole  -  Linux & Open Source Solutions
> http://www.sourcepole.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141117/776f88df/attachment.html>
