[gdal-dev] GDAL 1.11.1 OpenFileGDB driver with non-spatial tables
Christy Nieman cnieman at dmsolutions.ca
Mon Nov 17 07:15:39 PST 2014
That worked.  Building trunk allows me to see the non-spatial tables.  I
guess the FGDB was made with ArcGIS 9.x then.
Thanks again,
Christy
On 17/11/14 09:38 AM, Christy Nieman wrote:
> Thanks Even.  I'm not sure which version of ArcGIS created the FGDB,
> but I'll try building master and see if it works.
> Christy
> On 17/11/14 09:36 AM, Even Rouault wrote:
>> Le lundi 17 novembre 2014 15:23:54, cnieman at dmsolutions.ca a écrit :
>>> Hi all,
>>>   I did a little looking around, but was unable to find anything
>>> about this.
>>>   I have a File Geodatabase that I can read with the OpenFileGDB
>>> driver,
>>> and see all of the layers containing spatial data.  However, I seem
>>> to not
>>> be able to see non-spatial tables.  Is this expected?
>> Christy,
>> If the FGDB has been created by ArcGIS 9.X, this issue has been fixed
>> recently:
>> http://trac.osgeo.org/gdal/ticket/5673
>> Even
>>>   Thanks,
>>>   Christy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
