[gdal-dev] Define Virtual Format for a remote GeoJSON file
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Wed Nov 19 09:14:19 PST 2014
Hi Andrea,
The VRT is an XML format and hence you need to ensure the content is XML
compliant: your URL contained `&` characters that need to be escaped to
`&`. The following VRT works for me:
<OGRVRTDataSource>
<OGRVRTLayer name="OGRGeoJSON">
<SrcDataSource>http://www.provincia.caltanissetta.sitr.it/ArcGIS/rest/services/Immobili/MapServer/0/query?where=objectid+%3D+objectid&outfields=*&f=json</SrcDataSource>
<LayerSRS>EPSG:3004</LayerSRS>
<SrcLayer>OGRGeoJSON</SrcLayer>
</OGRVRTLayer>
</OGRVRTDataSource>
Best regards,
Homme
On 19/11/14 13:22, aborruso wrote:
> Hi Even,
> thank you.
> Even Rouault-2 wrote
>> Yes, you can use the URL as the datasource name expected by the VRT
>> format.
> I have tried with:
> <OGRVRTDataSource>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> But if I run "ogrinfo -ro my_virtual_format_file.vrt" I have:
> INFO: Open of `my_virtual_format_file.vrt'
> using driver `VRT' successful.
> 1: OGRGeoJSONERROR 4: Failed to read GeoJSON data
> If I run:
> ogrinfo -ro
"http://www.provincia.caltanissetta.sitr.it/ArcGIS/rest/services/Immobili/MapServer/0/query?where=objectid+%3D+objectid&outfields=*&f=json"
> OGRGeoJSON -summary
> It's all OK.
> What's wrong in my VRT definition?
> Thank you again,
> a
http://osgeo-org.1560.x6.nabble.com/Define-Virtual-Format-for-a-remote-GeoJSON-file-tp5173766p5173799.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141119/46673e1b/attachment-0001.html>
