[gdal-dev] gdal_calc.py: produce median raster
Marius Jigmond mariusjigmond at hotmail.com
Tue Nov 25 18:29:26 PST 2014
That's because numpy.median expects one array and keyword arguments, not three arrays. It's unclear to me what gdal_calc.py does under the hood (I admit I did not read it) but the correct way to get the median of the three bands would be:
--calc median([A,B,C], 0)
The strange part is that--calc median([A,B,C])works as well and generates a different output. When axis is not specified median should return a single value. At this point I suggest you take three 2D arrays, calculate their median as a 2D array, convert the three arrays to rasters, run gdal_calc.py and compare results.
-marius
Date: Tue, 25 Nov 2014 17:56:46 +0900
To: chris.yesson at ioz.ac.uk
CC: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdal_calc.py: produce median raster
Dear Dr Chris Yesson
Thanks for your quick response.
I got the following error:
ValueError: The truth value of an array with more than one element is ambiguous.
Use a.any() or a.all()`
Perhaps the expression for calc seems to be revised...
On Tue, Nov 25, 2014 at 4:59 PM, Chris Yesson <chris.yesson.phd at gmail.com> wrote:
Dear Simen,
You can refer to each band explicitly using the --A_band option.Try something like this
gdal_calc.py -A infile --A_band 1 -B infile --B_band 2 -C infile --C_band 3  --outfile outfile --calc median(A,B,C)
- ChrisDr Chris Yesson
Institute of Zoology, Zoological Society of LondonTel: 020 7449 6267
email: chris.yesson at ioz.ac.uk
web: http://www.zsl.org/chrisyesson/
Note: I work Mon-Thurs and do not check email on Fri
On 25 November 2014 at 07:44, Simen Langseth <simlangen at gmail.com> wrote:
Dear Respected Authors:
I would be grateful if you could share any hints on it.
On Tue, Nov 25, 2014 at 4:33 PM, Simen Langseth <simlangen at gmail.com> wrote:
Dear Marius Jigmond:
Thanks for your attempt.
Unfortunately, it is producing 3 band outfile, rather than 1 band median image.
I could not figure out what this code computed, all the resulted 3 bands images are also different.
I hope someone can help me.
On Tue, Nov 25, 2014 at 12:09 PM, Marius Jigmond <mariusjigmond at hotmail.com> wrote:
Does the following work:
gdal_calc.py -A infile --allBands=A --outfile=outfile --calc="median(A)"
Date: Mon, 24 Nov 2014 19:14:06 +0900
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] gdal_calc.py: produce median raster
I have one GeoTiff file with 3 bands. I want to produce a raster file computing pixel wise median value for the three raster bands. How can I do that?
I tried as follows:
gdal_calc.py -A infile --allBands --outfile outfile --calc median(A)
But could not get any out file.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This message has been scanned for viruses by MailControl, a service from BlackSpider Technologies.
Click here to report this email as spam.
The Zoological Society of London is incorporated by Royal Charter
Principal Office England. Company Number RC000749
Registered address:
Regent's Park, London, England NW1 4RY
Registered Charity in England and Wales no. 208728
_________________________________________________________________________
This e-mail has been sent in confidence to the named addressee(s).
If you are not the intended recipient, you must not disclose or distribute
it in any form, and you are asked to contact the sender immediately.
Views or opinions expressed in this communication may not be those
of The Zoological Society of London and, therefore, The Zoological
Society of London does not accept legal responsibility for the contents
of this message. The recipient(s) must be aware that e-mail is not a
secure communication medium and that the contents of this mail may
have been altered by a third party in transit.
If you have any issues regarding this mail please contact:
administrator at zsl.org.
___________________________________________________________________________
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141125/08b0c16d/attachment.html>
