[gdal-dev] RFC 47 and Threading
Blake Thompson
flippmoke at gmail.com
Fri Nov 28 10:12:18 PST 2014
Jacek and Even,
I already made an improvement on the pthread version of this:
https://github.com/flippmoke/gdal/blob/trunk/gdal/port/cpl_multiproc.cpp#L1135
I am sure we could do something similar to it to make an improvement in the
non pthread version.
Adding at line:
https://github.com/flippmoke/gdal/blob/trunk/gdal/port/cpl_multiproc.cpp#L165
We could do something like this:
https://gist.github.com/flippmoke/16cd26a0247422f25840
Thanks,
Blake
On Fri, Nov 28, 2014 at 11:49 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Jacek,
> Did you identify which call sites triggered hCOAMutex to be taken ?
> Ideally we
> should try to minimize them.
> For the sake of my curiosity, which method did you try to evaluate time
> spend
> in mutex sleeping ?
> Another improvement would be that instead of dynamically created mutexes,
> we
> could use statically created mutexes ( PTHREAD_RECURSIVE_MUTEX_INITIALIZER
> That would avoid that hCOAMutex to become the "BGL" (Big GDAL Lock :
> http://en.wikipedia.org/wiki/Giant_lock)
> Building GDAL with MUTEX_NONE and using it in a multi-threaded case is a
> potential risky game. This might work for some particular workloads &
> drivers,
> but not in the general case. For example even the GTiff driver needs a
> mutex to
> initialize libtiff/libgeotiff. See GTiffOneTimeInit() and there might be
> more
> subtle stuff elsewhere.
> But yes, I agree that an open flag to indicate per-dataset cache is an
> interesting track to explore.
> Even
> > Blake, Even,
> > I played a bit with pull request #39. I enabled per dataset cache by
> setting
> > GDAL_DATASET_CACHING to YES. Awesome work!
> > Our application code opens file in GDAL and holds GDALDataset per thread.
> > Different threads can request same blocks but because cache should be per
> > dataset i expected to see very little contention at the expense of some
> of
> > the blocks being read multiple times.
> > To my surprise i saw that nothing changed in terms of time spent
> sleeping.
> > After some investigation i realized that the contention point is static
> mutex
> > hCOAMutex. Having noticed that i saw MUTEX_NONE ifdef there so i decided
> to
> > define it to effectively get rid of mutexes in GDAL.
> > Guess what happened after recompilation. Because we only ever access
> > GDALDataset from single dataset and the new GDALBlockManager is now per
> > GDALDataset everything so far* (with the exception of PAMDataset
> destruction
> > because it does not like null mutexes) works fine and scales so much
> better
> > with the number of threads.
> > *Tested reading only using GTiff driver 4 threads reading tiles smaller
> than
> > blocks, sometimes two threads can read data from the same block .
> > Do you see the same problem with hCOAMutex?
> > It would be good if i could say: give me per dataset cache, open this
> dataset
> > with no locking. Unless the global cache provides its operations with
> less
> > sleeping.
> > Regards.
> > Jacek Tomaka
> > ________________________________
> > Od: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org]
> w
> > imieniu Blake Thompson [flippmoke at gmail.com]
> > Wys³ano: 29 sierpnia 2014 02:35
> > Do: Even Rouault
> > DW: gdal-dev at lists.osgeo.org
> > Temat: Re: [gdal-dev] RFC 47 and Threading
> > Even and Andre,
> > > I want to start off by saying a big thanks to Blake for taking his time
> > > to tackle what can only be a very difficult problem.
> > > From what I can observe, the current discussion seems to be around the
> > > boundary of who should be responsible for ensuring thread safety around
> > > the block cache. The core of GDAL versus the individual drivers.
> > The core will necessarily have to know about thread-safety because the
> block
> > cache is there. The discussion is more whether the drivers must also
> > necessary
> > be thread aware, or if core mechanisms are sufficient to hide this
> detail to
> > the
> > drivers. And potentially offering to drivers a mechanism to deal
> themselves
> > with
> > thread-safety if they can have a more optimized implementation than the
> > default
> > one.
> > Agreed, most specifically how to hide the detail of the protection of the
> > pointer to the block cache's data that is passed through IReadBlock,
> > IWriteBlock, and IRasterIO.
> > > While I
> > > see why such a conversation is important, as far as I am concerned, the
> > > most important part should be how it affects users of GDAL at the
> > > interface level.
> > Agreed.
> > > That is, if an application that is threaded is trying
> > > to use GDAL, how does it ensure thread-safety? What you have to keep in
> > > mind is that having some parts of the library not thread-safe basically
> > > just pushes the mutexing/locking to the calling applications.
> > Not necessarily. That's what I suggested in my previous email : if the
> costs
> > of
> > the mutex are not too expensive for non-threaded usage, then the API
> could
> > systematically return thread-safe versions, that are potentially wrapped
> by
> > GDALDatasetThreadSafe
> > So in the scope of my RFC, I am not certain how we could have a thread
> safe
> > cache and a non-threadsafe cache in any simple manner. I know that you
> are
> > specifically talking about the possiblity of thread safe datasets, which
> I
> > feel is necessarily part of this discussion but wanted to separate the
> two.
> > If the thread-safe cache is too expensive I feel like that is a major
> issue
> > however, and I am doing my best to avoid any performance hits for this
> > change.
> > > Also, while it is important to document thread-safety limitations,
> might
> > > I suggest adding thread-safe related capabilities (TestCapability),
> > > especially if all drivers do not end-up having the same thread-safety
> > > constraints.
> > That might be a solution, although not ideal from a usability point of
> view
> > (if
> > we come with something more complex that non-thread-safe vs thread-safe,
> that
> > might be difficult to understand by users of GDAL API), and from a
> > GDAL-developer point of view as well (need to assess thread-safety for
> each
> > driver).
> > There can have subtelties : imagine that the VRT driver is made to be
> thread
> > safe, but uses sources of drivers that might be not thread safe...
> > > I personally do not see a GDALDatasetThreadSafe wrapper as adding much
> > > complexity. For instance, if you were to add a capability that
> indicates
> > > if a driver is inherently thread-safe, you could add a new open method
> > > to open a dataset in a thread-safe way with something like the
> following
> > > pseudocode:
> > > DataSet OpenThreadSafe(GDALOpenInfo openInfo)
> > > DataSet dataSet = Open(openInfo);
> > > if (!dataSet.TestCapability(THREAD_SAFE))
> > > dataSet = wrapWithThreadSafeWrapper(dataSet);
> > > return dataSet;
> > Yes, that's similar to what I imagined with my idea of GDAL_OF_THREADSAFE
> > open
> > flag.
> > On the topic of the thread safe wrapper, I have spent more time thinking
> > about it and I think this is probably the best solution to the problem of
> > making all Datasets read safe, and I am willing to champion another RFC
> to
> > implement this. However, the scope of this is even larger because it
> should
> > be required to work with the OGR datasets as well.
> > Thanks,
> > Blake
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141128/a5d8af18/attachment.html>
