[gdal-dev] LZW Compression on geotiffs
Even Rouault
even.rouault at spatialys.com
Thu Oct 2 02:05:23 PDT 2014
Le jeudi 02 octobre 2014 09:55:17, Jukka Rahkonen a écrit :
> Rahkonen Jukka (Tike <jukka.rahkonen <at> mmmtike.fi> writes:
> > > True, a way to improve things might be to specify -co PREDICTOR=2.
> > > Should apply to both LZW and DEFLATE.
> > > This is one of the filter that might be used by PNG, except that PNG
> > > has
> different
> > > filters, so it will eventually beat TIFF deflate.
> > Not a bad suggestion.
> > Original 424 MB
> > DEFLATE without predictor 380 MB
> > DEFLATE with -co predictor=2 280 MB
> One more test with LZW
> Without predictor 474 MB
> With -co predictor=2 307 MB
> Is there something that prevents changing the default to "predictor=2" from
> the current default value "1"?
I guess you can find cases where predictor=2 leads to bigger sizes, otherwise
you could do several predictor passes and if each time the size would be
smaller, you would violate principles of the information theory (you would
compress less than the entropy of the data). But in practice, with non pure-
noise images, I think that horizontal differencing result in smaller files in
nearly all cases. Would be good to know if someone has lead a test campaign on
that, with various types of images, and particularly the ones involved in GIS.
There's at least one case I can think of where horizontal differencing would
likely have no effect, or some negative effect. For paletted images where the
index values of neighbour pixels have no correlation.
Adobe did apparently some tests, as mentionned in section 14 of
https://partners.adobe.com/public/developer/en/tiff/TIFF6.pdf, but they don't
compare the effect of horizontal differencing vs non-differencing. Interestingly
they mention a trick (masking of low-order bits) that can enhance the effect of
horizontal differencing at the expense of some loss of course. That's something
is only relevant on the compression side. Completely transparent for the
decompression side.
As raised by Andrea, there might be an impact of horizontal differencing on
decompression time, but I'd expect it to be small. There's only one integer
addition per sample value to undo the effect of the predictor.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
