[gdal-dev] RuntimeError no COPY in progress
Ari Jolma
ari.jolma at gmail.com
Thu Oct 2 12:32:14 PDT 2014
2014-10-02 19:23:03 EEST ERROR: COPY from stdin failed: COPY terminated
by new PQexec
> Hum, definitely weird. I've an idea to debug that. If you use GDAL trunk, you
> could enable the OGR C API spy mechanism, as the Perl bindings used the C API.
> That will produce a OGR Python script (sorry for Python ;-)) that should have
> the same side effects regarding the OGR PostgreSQL driver as your original Perl
> script.
> See http://www.gdal.org/ograpispy_8h.html
ok, I'll try that (recompile takes time) but an intermediate information
is that the situation occurs only when the same datasource is used for
reading and writing. I'm converting Polygons into LineStrings, so I'm
reading from the database the polygons from one table and writing back
lines into a different table. Now when I had two datasource objects to
the same database the problem did not occur again.
Ari
