[gdal-dev] NITF YCbCr To RGB?
Even Rouault
even.rouault at spatialys.com
Mon Oct 6 08:39:53 PDT 2014
Le lundi 06 octobre 2014 17:02:51, M Lewis a écrit :
> We have a software component where users can view/zoom/pan different map
> types.
> We use GDAL to read the specific part of the image using RasterIO as raw
> bytes and then convert to a bitmap for display.
> We are now incorporating viewing NITF files and am a little confused in how
> the NITF driver handles YCbCr colour space (which some of the NITFs have).
> I have found these little snippets from Frank that I found in another post
> from 2005:
> /'....Othewise YCbCr images are automatically converted to RGB internally.
> However, even in the (default) case where YCbCr images are converted to RGB
> internally I *think* that the NITFDataset will still return the YCbCr band
> types. This is a bug, and if you want it fixed please file a bug'/
> Also in the NITFDataset code there is a comment:
> / /* FIXME? Does it make sense if the JPEG/JPEG2000 driver decodes */
> /* YCbCr data as RGB. We probably don't want to set */
> /* the color interpretation as Y, Cb, Cr *//
> Here is a typical gdalinfo dump of a NITF file that I have to deal with:
> Band 1 Block=640x1 Type=Byte, ColorInterp=YCbCr_Y
> Overviews: 320x240, 160x120
> Image Structure Metadata:
> COMPRESSION=JPEG
> Band 2 Block=640x1 Type=Byte, ColorInterp=YCbCr_Cb
> COMPRESSION=JPEG
> Band 3 Block=640x1 Type=Byte, ColorInterp=YCbCr_Cr
> COMPRESSION=JPEG
> The question is can it be assumed (based on Franks comments) that in the
> decoding by the JPEG driver that Band 1 has been converted to Red even
> though it states above that the band is YCbCr?
Martin,
Yes, Frank's comment is right. The color interpretation is wrong. It should be
RGB, since on-the-fly colorspace conversion from YCbCr to RGB has been done.
That should be fixed
Even
http://www.spatialys.com
