[gdal-dev] strange problem with compilation
Even Rouault even.rouault at spatialys.com
Mon Oct 13 04:51:17 PDT 2014
On Monday 13 October 2014 13:41:11 Martin Landa wrote:
> Hi,
> 2014-10-13 13:33 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> > g++ -I /usr/local/include -L /usr/local/lib  -lgdal main.cpp
> > Error:
> > undefined reference to GDALAllRegister
> solved,
> g++ mail.cpp -I /usr/local/include -L /usr/local/lib -lgdal
> works (so `-l` after cpp file).
> Strangely g++ 4.7 works on both commands. Only g++ 4.8 fails...
Yes, I've hit similar issues recently. Newer g++ are very picky about the
order into which arguments appear on the command line for linking. You must
put -L -l after the file that need them.
> Huh, sorry for the noise, Martin
http://www.spatialys.com
