[gdal-dev] Conversion from ASCII to GeoTIFF with gdalwarp: incorrect output
Jamie Adams
jaadfoo at gmail.com
Tue Oct 14 15:52:27 PDT 2014
I would use the CENTER_LONG config argument. That will extend the raster
past the -180/180 boundary depending on which side you want to extend.
--config CENTER_LONG 180
Upper Left ( 176.0010322, -16.1523859) (176d 0' 3.72"E, 16d 9' 8.59"S)
Lower Left ( 176.0010322, -18.2685614) (176d 0' 3.72"E, 18d16' 6.82"S)
Upper Right ( 181.182, -16.152) (181d10'55.25"E, 16d 9' 8.59"S)
Lower Right ( 181.182, -18.269) (181d10'55.25"E, 18d16' 6.82"S)
--config CENTER_LONG -180
Upper Left ( -183.999, -16.152) (183d59'56.28"W, 16d 9' 8.59"S)
Lower Left ( -183.999, -18.269) (183d59'56.28"W, 18d16' 6.82"S)
Upper Right (-178.8179863, -16.1523859) (178d49' 4.75"W, 16d 9' 8.59"S)
Lower Right (-178.8179863, -18.2685614) (178d49' 4.75"W, 18d16' 6.82"S)
On Sun, Oct 12, 2014 at 1:43 PM, Lukasz Tracewski <
lukasz.tracewski at outlook.com> wrote:
> Hi,
> I have a few thousands of ESRI ASCII rasters in World_Mollweide
> (EPSG:54009) projection, which I need to convert to GeoTIFF. Usually it
> goes fine, but there are certain special cases that resist peaceful
> conversion. They are all placed on Fiji, which is special in a sense being
> on very border of a world's map. Problem is that in those cases somehow
> output is completely messed up, with incorrect resolution.
> Here is how I do the conversion:
> gdalwarp -s_srs '+proj=moll +lon_0=0 +x_0=0 +y_0=0 +ellps=WGS84
> +datum=WGS84 +units=m no_defs' -t_srs EPSG:4326 -co NBITS=1 -co
> COMPRESS=CCITTRLE -co PHOTOMETRIC=MINISWHITE -ot Byte $ascfile $newname
> My ASCII files are bilevel, with 0 and 1 only.
> Here is an example of a problematic ASCII:
> https://drive.google.com/file/d/0B46Cy3WOKgyJYVdMLWV0OGFJQ2M/view?usp=sharing
> That will produce GeoTIFF with only 3 pixels in latitude:
> https://drive.google.com/file/d/0B46Cy3WOKgyJTnoxSHdyaUR5cWs/view?usp=sharing
> Thing is if I crop the ASCII in QGIS to include only left side of the
> image, then it's fine. If I take the right side, then again I get incorrect
> output.
> Any ideas?
> Cheers,
> Lucas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141014/3eaabd6a/attachment.html>
