[gdal-dev] Create PostGIS database using OGR/GDAL
M. Edward (Ed) Borasky znmeb at znmeb.net
Thu Oct 23 13:48:57 PDT 2014
If this is a Windows-only project, you can write directly to PostgreSQL /
PostGIS using the ODBC driver. And if you have shapefiles, there's a
PostGIS utility called "shp2pgsql" that will import them.
On Thu, Oct 23, 2014 at 1:03 PM, Paul Meems <bontepaarden at gmail.com> wrote:
> Hi,
> At this moment we are working on getting PostGIS support for MapWinGIS.
> We use the PostGIS driver from GDALv2.
> So far we can read and write layers.
> We also want to implement some tests, which are also used as a show case
> for other users.
> For these tests I want to create a database, import some layers, doe
> something with the layers and drop the database again.
> Creating and dropping a database using ExecuteSQL() doesn't work as stated
> at the driver page:
> The PostgreSQL driver does not support creation of new datasets (a
> database within PostgreSQL), but it does allow creation of new layers
> within an existing database.
> The error I'm getting is "CREATE DATABASE cannot run inside a transaction
> block".
> Does anybody have an idea how to solve this? I don't want to manually
> create the database. The tests are more or less running automated. I would
> also like to prevent to bypass GDAL/OGR and connect to PostGIS directly to
> create and drop a database.
> Any suggestions are much appreciated.
> Thanks,
> Paul
> *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
> *The English presentations of the MapWindow GIS Conference 2014 are
> online. <http://www.slideshare.net/mapwindow>*
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Twitter: http://twitter.com/znmeb; Computational Journalism on a Stick
http://j.mp/CompJournoStickOverview
Remember, if you're traveling to Bactria, Hump Day is Tuesday and Thursday.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141023/da956492/attachment.html>
