[gdal-dev] How to merge 4 to 5 images per day using gdal-merge and cmd(.bat file)
user_name ljvillarin30 at gmail.com
Thu Oct 23 20:00:43 PDT 2014
There are 4 to 5 projected images in one day. Let's say I have all the
projected images for 3 days.
For day 1, the file name are:
T2010232034000.L2.Tera.tif
T2010232035000.L2.Tera.tif
T2010232036000.L2.Tera.tif
T2010232037000.L2.Tera.tif
For day 2, the file name are:
T2010233045000.L2.Tera.tif
T2010233046000.L2.Tera.tif
T2010233047000.L2.Tera.tif
T2010233048000.L2.Tera.tif
T2010233049000.L2.Tera.tif
For day 3, the file name are:
T2010234050000.L2.Tera.tif
T2010234051000.L2.Tera.tif
T2010234052000.L2.Tera.tif
T2010234053000.L2.Tera.tif
T2010234054000.L2.Tera.tif
How will I merge all the images that are for day 1, for day 2 and for day 3
and save each merged images to a new directory leaving only the
T/datayear/juliandate as the filename for each day. Merging files is easy
but doing it in batch and merging based on the images per day is making me
crazy.
Note: T2010232034000 = Terra/Data Year/Julian Date/HH/MM/SS
Code for merging files:
set in_path=path_to_in_file
set out_path=path_to_out_file
md %out_path%
cd /d %in_path%
FORFILES /C "cmd /c gdal_merge.py -n 0 -a_nodata -32767 -of GTiff -o @path
%out_path%\@fname.tif"
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-merge-4-to-5-images-per-day-using-gdal-merge-and-cmd-bat-file-tp5169282.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
