[gdal-dev] gdalwarp giving two different results with the same input
VILLARD, Pierre pierre.villard at capgemini.com
Fri Oct 24 02:06:40 PDT 2014
Hi Even, thanks for your reply !
On one side I had :
proj-4.7.0-1.el6.rf.x86_64
On the other (on the computer with expecting results) :
proj-4.8.0-3.el6.x86_64
With the same versions, I get the same results !
Thanks a lot !
-----Message d'origine-----
De : Even Rouault [mailto:even.rouault at spatialys.com]
Envoyé : vendredi 24 octobre 2014 10:28
À : VILLARD, Pierre
Cc : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] gdalwarp giving two different results with the same input
Le vendredi 24 octobre 2014 09:35:30, vous avez écrit :
> Hi,
> I am using GDAL (GDAL 1.9.2, released 2012/10/08) to change of EPSG
> referential on a GeoTiff file. I do the exact same command on two
> different computers (with the same version of GDAL and tiff libraries).
> And I get two different results... I am out of options, any idea ? Any
> place I should have a look ?
Pierre,
In case you did several attempts on computer B, did you erase output.tif before re-running gdalwarp ? gdalwarp will not do it (this is the mosaicing mode onto an existing target), unless you specify -overwrite.
Is the O.S., architecture and binary distribution of GDAL the same on both computers ?
Otherwise the other potential suspects might be the GDAL_DATA environment variable not defined or pointing to a wrong directory. Or different proj.4 versions.
Even
> Command :
> gdalwarp -s_srs EPSG:3975 -t_srs EPSG:4326 input.tif output.tif
> Input file :
> Driver: GTiff/GeoTIFF
> Files: input.tif
> Size is 1388, 584
> Coordinate System is `'
> Origin = (-17321655.543400000780821,7332251.365589999593794)
> Pixel Size = (24959.157843515851710,-25110.449882157532556)
> Metadata:
> lat#_FillValue=9.96921e+36
> lat#long_name=latitude
> lat#units=degrees_north
> lon#_FillValue=9.96921e+36
> lon#long_name=longitude
> lon#units=degrees_east
> NC_GLOBAL#conventions=CF-1.4
> NC_GLOBAL#creation_date=2014-10-20T16:12:01
> NC_GLOBAL#datum=+ellps = WGS84
> NC_GLOBAL#ease_global=yes
> NC_GLOBAL#ease_origin_lat=-83.517136
> NC_GLOBAL#ease_origin_lon=-179.87032
> NC_GLOBAL#ease_projection=cylindrical
> NC_GLOBAL#ease_resolution=25
> NC_GLOBAL#grip_mapping=projection
> NC_GLOBAL#history=none
> NC_GLOBAL#institution=SMOS CATDS Processing Chain
> NC_GLOBAL#netcdf_version_id=3.6.2
> NC_GLOBAL#product_version=1.0
> NC_GLOBAL#proj4text=+proj=cea +lon_0=0 +lat_ts=30 +x_0=0 +y_0=0
> +ellps=WGS84 +units=m +no_defs NC_GLOBAL#srid=EPSG:3975
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (-17321655.543, 7332251.366) Lower Left
> (-17321655.543,-7332251.366) Upper Right (17321655.543, 7332251.366)
> Lower Right (17321655.543,-7332251.366)
> Center      (   0.0000000,   0.0000000)
> Band 1 Block=1388x1 Type=Float64, ColorInterp=Gray
> On computer A (the result I am expecting) :
> Files: output.tif
> Size is 1355, 657
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0],
>     UNIT["degree",0.0174532925199433],
>     AUTHORITY["EPSG","4326"]]
> Origin = (-179.524544819822239,87.025797325816669)
> Pixel Size = (0.264973369536817,-0.264973369536817)
> Metadata:
>   AREA_OR_POINT=Area
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (-179.5245448,  87.0257973) (179d31'28.36"W, 87d
> 1'32.87"N) Lower Left  (-179.5245448, -87.0617065) (179d31'28.36"W,
> 87d 3'42.14"S) Upper Right ( 179.5143709,  87.0257973)
> (179d30'51.74"E, 87d 1'32.87"N) Lower Right ( 179.5143709, -87.0617065) (179d30'51.74"E, 87d 3'42.14"S)
> Center      (  -0.0050870,  -0.0179546) (  0d 0'18.31"W,  0d 1' 4.64"S)
> Band 1 Block=1355x1 Type=Float64, ColorInterp=Gray
> On computer B :
> Files: output.tif
> Size is 1358, 651
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
> Origin = (-179.674959335984454,86.219877359659435)
> Pixel Size = (0.264688310439600,-0.264688310439600)
> Metadata:
>   AREA_OR_POINT=Area
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (-179.6749593,  86.2198774) (179d40'29.85"W,
> 86d13'11.56"N) Lower Left  (-179.6749593, -86.0922127)
> (179d40'29.85"W, 86d 5'31.97"S) Upper Right ( 179.7717662,
> 86.2198774) (179d46'18.36"E, 86d13'11.56"N) Lower Right ( 179.7717662, -86.0922127) (179d46'18.36"E, 86d 5'31.97"S)
> Center      (   0.0484035,   0.0638323) (  0d 2'54.25"E,  0d 3'49.80"N)
> Band 1 Block=1358x1 Type=Float64, ColorInterp=Gray
> Thanks for your help !
> Regards,
> Pierre.
> This message contains information that may be privileged or
> confidential and is the property of the Capgemini Group. It is
> intended only for the person to whom it is addressed. If you are not
> the intended recipient, you are not authorized to read, print, retain,
> copy, disseminate, distribute, or use this message or any part
> thereof. If you receive this message in error, please notify the
> sender immediately and delete all copies of this message.
> gdal-dev mailing list
Spatialys - Geospatial professional services http://www.spatialys.com
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
