[gdal-dev] Transform pixel coordinates
Artur Bercik
vbubbly21 at gmail.com
Sat Oct 25 03:00:09 PDT 2014
On Sat, Oct 25, 2014 at 5:05 PM, Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 25.10.2014 um 09:29 schrieb Artur Bercik:
>>> sorry, yes the pixel size are in degrees,0.047 deg.(5 km approx. at
>> equator), in GCS and WGS84.
> Ok, then it is easy. Using the values from your other post:
> upperLeftX, upperLeftY = 150.1234, 50.1234 (They are in GCS with WGS84
> datum)
> pixelWidth, pixelHeight = 0.047, 0.047
> totalColumns, TotalRows = 270, 406
> and assuming the coordinates are East and North positive. To georeference
> the image, set the extent in gdal_translate with -a_srs EPSG:4326 and
> -a_ullr ulx uly lrx lry
> ulx and uly are known, the others are
> lrx = ulx + 270 * 0.047
> lry = uly - 406 * 0.047
> This does not work if your image is not North-orientated.
> HTH,
> André Joost
Thank you very much, I have adopted it.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141025/897c25fc/attachment.html>
