[gdal-dev] Point SYMBOL
Alexandre Busquets abusquets at gmail.com
Mon Oct 27 16:59:48 PDT 2014
I'm writing  a shp to dxf converter and I have a problem with the points.
The style is not applied (I only see a small point).
I have not problem with the lines and the polygons, only with the points.
This is a sample of my code adapted for this email.
data_source = ogr.GetDriverByName('DXF').CreateDataSource(fitxer_desti,
['HEADER=header.dxf'])
lyr = None
try:
    lyr = data_source.CreateLayer('entities')
except Exception:
    raise FitxerException('Can not open')
dst_feat = ogr.Feature(feature_def=lyr.GetLayerDefn())
style = 'SYMBOL(id:ogr-sym-3,c:#FF0000,s:50px)'
dst_feat.SetStyleString(style)
dst_feat.SetGeometryDirectly(geom)
dst_feat.SetField('Layer', 'points_sample')
lyr.CreateFeature(dst_feat)
Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141028/6367d101/attachment-0001.html>
