[gdal-dev] Convert S57 to image with S52 rendering
s duclos
sylvain_duclos at yahoo.com
Mon Sep 1 08:47:08 PDT 2014
Storkur,
I think that you should be fine with glib-2.0 (2.31)
I'm on Ubuntu 14.04 witch have glib 2.40.0 and I just tried the target s52glx.
Work fine here.
But if you can't upgrade your glib then maybe the old way work for you
Simple test would be to comment line S52.c:271 and add:
static GStaticMutex _mp_mutex = G_STATIC_MUTEX_INIT;
In recent glib GStaticMutex is deprecated.
rgds,
Sylvain.
On Mon, 9/1/14, Storkur <sovofmad at yandex.ru> wrote:
Subject: Re: [gdal-dev] Convert S57 to image with S52 rendering
To: gdal-dev at lists.osgeo.org
Received: Monday, September 1, 2014, 5:00 AM
Sylvain,
Thanks
But i cant build s52 lib.
I try
make s52glx command, but it says S52.c:271: error: storage
size of
‘_mp_mutex’ isn’t known
I probably resolve all dependencies.
View this message in
context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Convert-S57-to-image-with-S52-rendering-tp4987897p5159378.html
Sent
from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
