[gdal-dev] GetFeatureCount() bForce set to FALSE
Even Rouault
even.rouault at spatialys.com
Mon Sep 8 07:22:27 PDT 2014
Martin,
I'm far from being a C++ expert, but I don't think it makes sense to change the
default value of an optional parameter of a virtual method in a child class of
the base class.
http://svn.osgeo.org/gdal/trunk/gdal/ogr/ogrsf_frmts/ogrsf_frmts.h :
virtual int GetFeatureCount( int bForce = TRUE );
My suggestion would be that you remove the (|| bForce) test in your
implementation, if the poDataBlock->GetFeatureCount() is reliable.
Even
> Hi all,
> I was trying to change a default value of bForce in
> OGRVFKLayer::GetFeatureCount() to FALSE [1], but when I debug eg.
> ogrinfo, it still reports bForce as TRUE (1)
> Breakpoint 1, OGRVFKLayer::GetFeatureCount (this=0x71a7d0, bForce=1)
> at ogrvfklayer.cpp:162
> Any idea what could be wrong?
> Thanks in advance, Martin
> [1]
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/vfk/ogr_vfk.h#L83
> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
