[gdal-dev] Python error (missing?) when performing RasterizeLayer on specific polygon with two very close vertices
Even Rouault even.rouault at spatialys.com
Tue Sep 9 10:37:30 PDT 2014
Le mardi 09 septembre 2014 18:08:16, Casper Børgesen (CABO) a écrit :
> I have tried with GDAL 1.11 and Python 3.2 (again the builds are from
> GISInternals), and it gives me the same result. Python just terminated
> without any warning or error.
> Both versions of GDAL are x64.
Casper,
This is probably an issue with the rasterization algorithm itself. I'd suggest
you to provide a fully reproducible sample script (i.e. without "...") and put
it/attach it in a new ticket at http://trac.osgeo.org/gdal/newticket
Best regards,
Even
http://www.spatialys.com
