[gdal-dev] Uint16 geotiff
Frank Warmerdam
warmerdam at pobox.com
Wed Sep 10 10:36:53 PDT 2014
Gdalwarp generally does not propagate metadata from the source(s) to the
output file. One approach is to use gdal_translate after to re-add desired
metadata. Alternatively you could precreate the output file and populate
it with metadata. I often do this part in python.
Best regards,
Frank
On Sep 10, 2014 10:17 AM, "Nikolaos Hatzopoulos" <nhatzop at gmail.com> wrote:
> Dear All,
> so I have an RGB image in tiff format with uint16
> when I use gdalwrap the TIFFTAG_MINSAMPLEVALUE
> and TIFFTAG_MAXSAMPLEVALUE are magicaly disappearing
> from the result image
> WHYYY???
> --Nikos
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140910/cc9d02c9/attachment.html>
