[gdal-dev] white line between tiles when using gdal_translate on a vrt file
00darki alex.jong0019 at gmail.com
Tue Sep 16 02:01:56 PDT 2014
Hello,
I've a problem when I use gdal_translate on a vrt, some lines appear on the
generated image.
These lines correspond to the border of each small image referenced in the
vrt.
These images have been reprojected to mercator projection.
Lines appears randomly at some zoom levels.
I thought the overview (by gdaladdo) were the problem, but when I delete the
.ovr file, this doesn't make any difference.
Thanks for any help :)
<http://osgeo-org.1560.x6.nabble.com/file/n5162050/img_bug.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-white-line-between-tiles-when-using-gdal-translate-on-a-vrt-file-tp5162050.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
