[gdal-dev] white line between tiles when using gdal_translate on a vrt file
00darki alex.jong0019 at gmail.com
Wed Sep 17 02:04:52 PDT 2014
Yes, I warped each file individually and the .vrt is the index containing all
warped files.
I added -tr and -tap option and apparently the problem is solved !
Thanks a lot !! :)
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-white-line-between-tiles-when-using-gdal-translate-on-a-vrt-file-tp5162050p5162284.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
